Posted by rustyfarmall on January 14, 2010 at 10:39:12 from (209.152.78.140):
In Reply to: hauling my tractor posted by ScottyHOMEy on January 14, 2010 at 05:01:46:
NDS said: (quoted from post at 10:53:18 01/14/10) Rusty can you cite an actual case where highway patrol has pulled someone over and impounded v
ehicle because they thought they were overweight. Most highway patrol officers would not have a clue of what M weighed. I agree he definitely should not try it.
They might not have a clue as to the weight, but that is not the real issue here. The real issue is that the combination is a classic example of an unsafe vehicle, small truck, large trailer, even larger tractor, and yes, I have seen the highway patrol stop and impound vehicles that are unsafe.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
