Posted by NDS on January 14, 2010 at 13:05:12 from (64.12.116.73):
In Reply to: Re: hauling my tractor posted by rustyfarmall on January 14, 2010 at 12:17:18:
Can you cite statues that says exceeding GVWR is illegal, couple years ago I read weight laws for every state and CN and some NW state was only states that said exceeding GVWR was illegal. In most states exceeding registered weigh is illegal and some states will let you register over GVWR and some will not. Mazda pobaly has 1500 lb. or so payload capacity and I doubt that tongue weight will put him over that might exceed rear GAWR and tire ratings though. Exceeding GCWR is not illegal in any state as that is a floating number that changes as equipment on truck is changed.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
