Posted by farmallhal on January 14, 2010 at 13:48:32 from (71.1.111.67):
In Reply to: Re: hauling my tractor posted by AndrewFromNS on January 14, 2010 at 12:47:18:
Andrew, your Super C is more then 2000 pounds lighter then a standard M. The H is a little lighter then 4000 pounds. These weights are from Guy Fays IH Tractor Data Book. It list the Super C at 2900 pounds without extras like wheel weights and loaded tires. I recently hauled my Super C on a 24 ft. BobCat trailer behind a Dodge 3500 (1 ton with dual rear tires) and it was like nothing back there. I put the rear tractor tires over the dual trailer axles and had what seemed like the proper amount of tongue weight on the pintle hitch. I'm sure a 3/4 ton would be fine for hauling a Super C as the trailer weight wouldn't have to be that much compared to a trailer for hauling a M. Hal
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
