Re: 450 will not restart after it is warmed up
Posted by Andrew Z on January 14, 2010 at 16:01:47 from (64.252.113.90):
In Reply to: 450 will not restart after it is warmed up posted by SDE on January 14, 2010 at 15:33:59:
Sounds like your coil or condensor is going dead. It is a classic bad coil sign when you can start the tractor when cold yet after awhile it stalls or will not restart. What you need to do is when it will not start pull a plug and check for spark. If you see none or a very fait/orange/yellow spark then the coil is bad. If you have anouther coil off anouther tractor or one lying around then its easy to try it. Only takes a few seconds to change one out.
Andrew
This post was edited by Andrew Z at 16:04:45 01/14/10.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
