Re: Serial Numbers
Posted by Andrew Z on January 14, 2010 at 16:10:22 from (64.252.113.90):
In Reply to: Serial Numbers posted by RMckeithen on January 14, 2010 at 16:04:22:
If the engine is one that B came with from factory it will have the same serial number. The number you have off the engine indicates a 1945. You can also look for cast codes on major cast parts, like the block right below the dist/mag and side of the trans is one too. Youll be looking for a 'O' cast code. example will be - 3 12 O - = would mean that part was cast on March 12 1945.
Andrew
