Re: hauling my tractor
Posted by farmallhal on January 14, 2010 at 17:33:34 from (71.1.111.67):
In Reply to: Re: hauling my tractor posted by AndrewFromNS on January 14, 2010 at 15:44:23:
Andrew, Nothing was intended I was just giving you the weights as specified for a standard tractor. I had no information if you had it weighed on a scale or not. I was just sharing info for your benefit in case you were unaware. Sounds like you are very informed about your tractors and of course they are all different depending on the configuration. My SC is a narrow front with one set of rear weights with a fast hitch. I really don't know what the actual weight is but feel my H is quite a bit heavier. I know what a M is like as I raised mine the other day with a 3 ton floor jack and it was all it wanted on one axle. With the added weight on your tractor you are certainly in the 3/4 or one ton level with your tractor. None of my Farmalls have loaded tires but we probably use them for different tasks. Thanks Andrew for sharing but nothing more then information sharing was intended, Hal.
