Re: hauling my tractor
Posted by deano4863 on January 14, 2010 at 18:23:48 from (76.30.75.21):
In Reply to: Re: hauling my tractor posted by heavy hauler too on January 14, 2010 at 14:47:10:
Your a little heavy according to my Dodge 2500 owners manual that says that the truck, trailer, and load not exceed about 22,000 lbs. The 3500 dodge will go about 23,000lbs. This is going from memory but I know I'm close. Check your owners manual. Provided your equipment is in good shape you shouldn"t have any issues. Here in TX the guys used to routinely haul back hoes with 1 ton trucks. probably in the 30K lb range. TXDOT has put a stop to that by writing tickets and taking the vehicle out of service on the spot. Put the guys in the position of unloading the back hoe and getting a bigger truck.
