Farmall H lift All hydraulics
Posted by Aaron Mattern on January 14, 2010 at 19:21:25 from (96.61.7.252):
I have a oil leak at the oil fill cap. When I have the lift all engaged it starts to leak oil. I have removed the pump and found the relief valve spring lever broke, and I found what was left of the breather felt in the relief valve itself. Removed felt and replaced relief valve and lever but problem still exists. Checked pump pressures and everything was ok. Has anyone had this problem before or have any ideas what else I can do.
