Re: 450 will not restart after it is warmed up
Posted by El Toro on January 15, 2010 at 03:56:35 from (74.103.74.58):
In Reply to: 450 will not restart after it is warmed up posted by SDE on January 14, 2010 at 15:33:59:
When the engine quits running pull the coil wire out of the distributor's cap and hold it near a good ground. You will need a helper. Should have a hot blue spark. Yuo need to do this asap before the coil or engine cools. If there's very weak or no spark replace the coil. You also need a fully charged battery to supply a constant supply of battery voltage to the ignition. If you still have hot fire when it quits you probably have a fuel problem.
Pull the gas line at the carb and see if there's a full stream of gas from the tank. Hold a clean container to catch the gas. If that looks ok and you don't have just a trickle remove the tube fitting at the carb and look for a screen behind the fitting could be plugged. Hal
