Re: injector pump seal
Posted by jdemaris on January 15, 2010 at 07:55:14 from (72.171.0.148):
In Reply to: injector pump seal posted by plow hand on January 14, 2010 at 16:59:23:
If it's a CAV pump, you can take the top cover off the pump (no need to remove entire pump) and put in new seals with a cost around $20.
