Re: Farmall cub clutch parts- imports?
Posted by El Toro on January 16, 2010 at 09:42:20 from (74.103.74.58):
In Reply to: Farmall cub clutch parts- imports? posted by Geoff L on January 15, 2010 at 19:31:31:
third party image
Call Carolina Clutch at 1-800-374-2212. They can probably reline your clutch disc like new & rebuild your pressure plate if it needs it.
When I did a Farmall A a brake shop in Baltimore
relined my clutch disc. Hal
