Posted by Harold H on January 17, 2010 at 10:23:55 from (98.18.180.54):
In Reply to: 300 Farmall posted by RDJ Farms on January 17, 2010 at 10:07:21:
The Farmall 300 is the same frame size as derived from the Farmall H. Most have a IPTO but it was optional and some are only equipped for a standard PTO. Live hydraulic were standard but the number of hydraulic valves varies. Two point fast hitch was also optional and now many have been converted to or added three point hitch. As far as mounted implements like cultivators, middle busters, etc, most front mounted implements that fit an H or SH will fit the 300 and the rear section will fit if you don't have two or three point hitch. If you do, you will have to have a two or three point rear section to go with the mounted front section. Also, some front mounted implements will only work with tricycle front whereas some will work with wide or tricycle front. Most likely I would think you will be using three point hitch rear mounted equipment however.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
