Re: 560 Hyds.
Posted by pete 23 on January 17, 2010 at 10:40:10 from (173.87.15.32):
In Reply to: 560 Hyds. posted by Agri King on January 16, 2010 at 06:11:25:
Valves are actually closed center but the flow is directed to dump through the regulator,(not relief )valve. Operating a valve uncovers a passage that cuts off flow to regulator valve through the orfice screen and therefore regulator ball closes allowing fow to be directed to valves. Relief valve is in same block as regulator valve and provides maximum pressure relief to dump.
