Re: Super M Head part #
Posted by Andrew Z on January 17, 2010 at 19:43:00 from (64.252.113.90):
In Reply to: Re: Super M Head part # posted by deano4863 on January 17, 2010 at 19:22:01:
You will not have a problem running a domed piston with that head. The term low compression is used to described a head that is designed to burn kero or distilate fuels. You can mill the head down to increase compression but you will need to take it down quite a bit to get even get close to a stock high compression head. The diffrenence in compression is, the low compression will have around 90 psi while the high compression gas will have around 130psi. As D said check your tag for a suffix it could have been ordered like that from factory. If your not planning on pulling or heavy tillage then that head will be fine. What are you planning on doing with that Super M?
Andrew
