Re: farmall 200 hydraulics
Posted by Randy in NE on January 18, 2010 at 04:08:48 from (204.124.192.32):
In Reply to: farmall 200 hydraulics posted by kuntryboy on January 16, 2010 at 19:02:51:
The 200 is not going to have a large enough hydraulic reservoir to operate a one-way cylinder. As you extend the cylinder it is draining all of your oil out of the system. With a two way system, as you extend the cylinder the oil on the back side of the piston is pushed back into the system via the second hose. That way the volume in the system remains constant. With a one way cylinder, the weight of the implement is what pushes the cylinder piston back and causes the oil to flow back through the one hose.
