Re: Broken Crankshaft Pulley
Posted by Samuel Eubanks on January 18, 2010 at 19:12:36 from (76.6.124.99):
In Reply to: Re: Broken Crankshaft Pulley posted by randy hall on January 18, 2010 at 18:34:07:
Those are my thoughts. I do however want to hear if someone has had a good or bad experience.
Thanks!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
