Re: hydraulic fluid and level
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by POTOSI on April 29, 2000 at 18:53:47 from (24.142.140.88):
In Reply to: hydraulic fluid and level posted by Eric Wood on April 29, 2000 at 18:01:39:
I AM PRETTY SURE THAT YOU CHECK FLUID LEVEL WITH TRACTOR ON LEVEL,CYLINDER PISTON RETRACTED,FLUID SHOULD BE ABOUT 1/2" BELOW THE FILL HOLE.SOME WOULD SAY USE "HI-TRAN' FROM INTERNATIONAL,HOWEVER ANY GOOD QUALITY HYD.OIL WILL WORK.
Post A Followup
: Re: Re: hydraulic fluid and level
