Re: super m head gasket
Posted by sflem849 on January 19, 2010 at 05:17:37 from (66.254.196.101):
In Reply to: super m head gasket posted by Brian Love on January 17, 2010 at 15:53:03:
jdetig1 said: (quoted from post at 21:24:21 01/18/10) where would be the best place to buy a leakage tester. thanks
Your better auto parts stores should carry one. Of course there is always the internet. They want $40. As I searched they only go up from there. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94190&xcamp=google&utm_source=googlebase&utm_medium=cpc&zmam=33951326&zmas=12&zmac=112&zmap=94190 BTW these testers are also usefull for a few other tests. You can pinpoint bad rings and valves with them as well.
I am of a different opinion on this one than Pete. I would do the cyl test, but I would not pull the oil pan and screw around there. By the time you pull the oil pan and do all that jazz you could just throw a head gasket on it. I would CERTAINLY retorque the head (since the manual calls for it anyhow) and test/run it again. Even if the head gasket was on and torqued only for a few minutes it still wasn't the same as a brand new gasket.
