Re: electrical problems with conversion
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 29, 2000 at 19:16:00 from (152.163.207.208):
In Reply to: electrical problems with conversion posted by gene on April 29, 2000 at 16:12:41:
Does the solenoid click when you push the button? If it does, then most likely the starter's bad (probably the brushes worn out....)
Try connecting the battery + terminal to the power terminal on the starter with a jumper cable (you may get a spark!). If the starter does nothing, the problem's with the starter. If the starter turns, problem's in the solenoid or cabling.
Good luck!
Post A Followup
: Re: Re: electrical problems with conversion
