Posted by mike in new mexico on January 19, 2010 at 17:57:47 from (66.208.120.230):
What position do you install the control valves into the valve body? I know they are marked and have put them into the correct holes but they can still be 180 degrees out. By marked, I mean there is a single notch on one and two notches on the other. The left side has one and the right is the one with two. Do the notches go up or down? Thanks--MIKE
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
