Re: Farmall M transmission input shaft
Posted by D Slater on January 20, 2010 at 07:11:29 from (71.164.36.121):
In Reply to: Farmall M transmission input shaft posted by CumminsDan on January 20, 2010 at 04:44:32:
Gear size is the same for a M and SM but the shaft was changed on M tractors near the end of 1951 production and the same shaft was used on SM tractors. Late shaft is just a little different length and a bigger bearing was used on the front of shaft. Input shaft bearing housing, bearing retainer, and the front yoke or coupling were some things changed at the same time. As already said 400 and 450 are different.
