Re: 12V Conversion?
Posted by Loren MN on January 20, 2010 at 09:08:03 from (64.65.174.118):
In Reply to: 12V Conversion? posted by Farmall M Beginner on January 19, 2010 at 17:31:00:
I changed my M to 12V in 1999, and still have the same battery in it, over 10 yrs. later. I usually never sits more than a few weeks without being driven. I found a 12V generator from an MD diesel that I had rebuilt, and it works great. The MD generator is a perfect swap for the standard 6V generator, and is the easiest way to go. I changed the light switch to from 4 position to 3 position, since you wouldn't need the L & H charge, but that probably can be worked around with the existing switch too.
I'm planning on converting my H this winter. I found a 12V Delco generator at a swap meet that appears identical to the 6V. Not sure how someone had done that, but I had it tested and it works.
I wouldn't put an alternator in an M, since a 12V generator fits better and looks more original.
The starter does not need any changes. Just change the battery cables for negative ground and wire up the voltage regulator.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
