Re: gas tank repair was full of water
Posted by mkirsch on January 20, 2010 at 09:36:53 from (64.80.108.55):
In Reply to: gas tank repair was full of water posted by Brian Peppler on January 20, 2010 at 07:01:18:
There's a product called Evapo-Rust that worked pretty good on a 3-wheeler tank I needed to de-rust.
Only problem with it, it's water-based, and will freeze. I had a chumcicle to thaw out.
$20 a gallon though, and you either need to be able to position the tank and let it soak for a couple of days in each area, or you need enough to fill the tank. 5 gallon containers are probably a little cheaper.
