There are three things that could be going bad here. The first is that the bushings in the starter are gone bad, there are two one in the front cone and one in the back drive plate. The second thing that could be the problem is starter bendix is going/gone and or stuck and full of old grease and dirt. It also could have a worn out bendix gear, the gear that locks into the ring gear to start. Or it could be a combo of the both bad bushings and bendix. The third is the ring gear on the flywheel is worn out. What i would do is pull the starter off and clean the bendix groves out very well, it is on a sprial. At the same time check the starter for slop in the bendix (wiggle it back and forth to check for play). Also check the ring gear to see if the teeth look like they are smashed or broken.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
