Re: Super A 3 Point Measurements
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Peter Tutuska on April 29, 2000 at 20:21:00 from (216.70.65.179):
In Reply to: Super A 3 Point Measurements posted by Ed Fisher on April 27, 2000 at 05:37:04:
Ed:
The lift arm is 21 1/2" long, ball center to ball center. The hole for the lifting linkage is 15" from the ball center that attaches to the axle pad.
Good luck with your project!
Just a thought...I ended taking off the left side linkage arm that Worksaver supplied and instead I used a upper link. It made the linkage be adjustable (up and down) and it allowed the lower lift arm to swing outward better when your hooking up an implement.
Peter Tutuska
Post A Followup
: Re: Re: Super A 3 Point Measurements
