Posted by M Diesel on January 20, 2010 at 16:58:49 from (12.24.61.12):
In Reply to: 400/450 diesel posted by Bob on January 19, 2010 at 20:08:00:
f826 said: (quoted from post at 21:08:00 01/19/10) when i start my 400 and 450 after sitting overnight both have a lot of smoke at first then clear up then when i switch over to the diesel side they go full throttle then back down to idel. any ideas to what causes this?
I have a TD18A that does it too. It started doing it after an engine swap and I haven't had time to completely nail it down. It probably means the fuel rack isn't closing off when the engine is first firing up on gas. At low speed the governor is trying to kick in some fuel and the cold oil is hampering it. Have you tried 10W oil?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
