Re: gas tank repair was full of water
Posted by Rusty Acres, ND on January 20, 2010 at 18:33:54 from (64.31.251.187):
In Reply to: gas tank repair was full of water posted by Brian Peppler on January 20, 2010 at 07:01:18:
When we had an M with a rusty gas tank, we took the tank off, threw in a few handsfull of old nuts and bolts, added some water and strapped it to the wheel of another M. We then used the second M normally, and after driving for a while, the tank was clean and as a bonus we had some clean nuts and bolts. After about 15 years of use, the tank is still clean today.
Also, around here, most good radiator shops also clean and repair gas tanks.
