Re: farmallsuperc
Posted by Keith-OR on January 21, 2010 at 08:26:40 from (97.120.11.213):
In Reply to: Re: farmallsuperc posted by mkirsch on January 21, 2010 at 05:21:11:
because with this setup you don't have those rods in your way on both sides of the tractor. You run hydraulic lines out the way, ad use a spool valve to control lift cylinder. You also have down pressure if you so desire.
And it is not that hard to mount on a Farmall SC or C tractor. I purchase one off of a SC, looks like a Sagenal 3pt setup, from a friend. As soon as I can get backup to Moses Lake, WA I'll post pictures of the setup.
It is hard for me to get time to get a way this time of year as I couch Special Olympics and I am the LPC (Local Program Coordinator) also.
Keith & Shawn(Gold Medal Winner)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
