Re: Long term storage of Farmall H
Posted by Keith In Ga on January 21, 2010 at 22:30:55 from (72.15.97.115):
In Reply to: Long term storage of Farmall H posted by ryanwheelock on January 21, 2010 at 06:12:31:
If I were you, I'd mix some stabil in the gas and make sure it gets through the fuel system if it's going to be sitting for a long time. If you get the tires off the ground it will help prevent dry rot on the bottom. Depending on how dry the barn is, you might want to spray the whole thing down with a light film of oil if the paint isn't so good to prevent any more rust. You could fog the engine but it sounds like it locking up isn't an issue. As far as blocking the clutch pedal, that will prevent the clutch from getting stuck but it will also weaken your pressure plate springs over time. If your barn is nice and dry, I think I wouldn't block the clutch engaged.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
