Re: 706 torque tube
Posted by Owen Aaland on January 22, 2010 at 03:49:30 from (65.161.86.2):
In Reply to: 706 torque tube posted by 460anger on January 21, 2010 at 18:05:13:
The lower PTO gear is only a slip fit on the shaft. It is held in place by the front bearing. You will not be able to remove it until the center housing is moved forward. They like to stick on the splines of the shaft so you usually have to wiggle them a little as you move the housing ahead.
With the release of the 2 + 2 series tractors, IH made available a pair of special tools to hold the gear against the bearing to avoid having to remove it from the housing. For the most part they are more trouble than they are worth.
