Re: Ah..Gremlins in a 340 utility
Posted by Brownie 450 on January 22, 2010 at 06:16:58 from (66.43.241.141):
In Reply to: Ah..Gremlins in a 340 utility posted by Mark W. on January 22, 2010 at 04:33:33:
With everything dead, use the voltmeter on the battery posts to see if you have 12-volts. If you have 12-volts on the posts, go to the cable ends which attach to the posts. If there is no voltage here, your battery terminals/ posts need cleaned/ tightened. Report back with what you find.
