Re: Plow
Posted by Davset on January 22, 2010 at 06:55:04 from (97.89.99.98):
In Reply to: Plow posted by Allan from PA on January 22, 2010 at 05:48:50:
It is most likely for the A-91 single moldboard plow. The rockshaft is about 1.25" in diameter with a hand-screw adjustment on the left-hand side correct?
I am almost finished restoring one, although it is manual lift, everything from the rockshaft down is the same. I hope to get it attached in the next couple weeks and post some pictures.
  • Re: Plow Dave H (MI) 07:55:52 01/22/10 (0)
