Re: 460 Wide front
Posted by D Slater on January 22, 2010 at 07:02:40 from (72.65.157.252):
In Reply to: 460 Wide front posted by Red 1566 on January 21, 2010 at 08:08:34:
The only difference between a 460 and 560 farmall wide front is the spindle shafts size for the wheel bearings and hubs. Putting either on on a 350 requires the stay rod ball bracket change or modification as Rusty said and the steering arm change or modification. Support bracket is to wide for the 350 and height is off a little. Steering arm has a wider bolt spacing and bolt size than a 350. If not using the 460 or 560 hubs, special bearings or spacers may be needed to install the 350 hubs.
