Re: sm 400 ,450 water pump
Posted by Marty K on January 22, 2010 at 09:02:54 from (135.245.10.5):
In Reply to: sm 400 ,450 water pump posted by redgems on January 21, 2010 at 20:00:24:
Ah, the brass spanner packing nut! I borrowed a spanner wrench from my brother for mine, but I was considering grabbing a piece of metal from my scrap pile and making something myself with two opposing tabs that fit in the recesses of the nut. That would be better than using a pair of channel lock pliers on it (or a pipe wrench). Those mess things up too much. Good luck.
