If the pump shaft drive parts are left in place I have about as good luck with the right shaped bar, if the nuts not real tight. Put it in a slot at the right angle to hold and also contact drive stud, then turn fan blade. Simplist thing for damaged packing nut slots that works for me if nut is removed, is to grind nut flat on two sides so a open end wrench fits. Then when it back on I have a thin open end wrench that fits. Just have to turn the fan at the same time wrench is turned to keep drive studs clear of wrench.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
