Re: 460 utility w/bad TA
Posted by Janicholson on January 22, 2010 at 13:36:19 from (199.17.6.222):
In Reply to: 460 utility w/bad TA posted by Dave Paxton on January 22, 2010 at 12:20:03:
Andrew Z is correct (as usual) the TA repair is mostly the labor of the splits needed to do it. The kit (if found) would both be reducing the utility valus and cash value, but also the TA might not need more than a ner one way clutch and a disk to make it perfect. If kept in adjustment, and used regularly (and with rapid full travel of the control lever), they are way bullet proof.
Jim
