Re: 460U hydraulics surging
Posted by bc on January 22, 2010 at 19:43:21 from (71.158.221.179):
In Reply to: 460U hydraulics surging posted by Al L. in Wisc. on January 22, 2010 at 14:17:59:
Does it get better when it warms up. I'd look at the screen and filter. May have enough water and gunk that it freezes and doesn't allow full flow to pass to the pump. That tends to make it cavitate.
If that isn't it, then look for a blockage somewhere that is causing the relief valve to keep engaging such as the valve you suggested.
Or there is air leaking around the shaft in the tranny housing causing it to cavitate and filling it up with a few extra gallons of hytran fixes that.
Let us know what you find. I start with cleaning the filter and screen and then add extra fluid before tearing valves apart.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
