Re: setting the timing on a 574 diesel d239 engine
Posted by jimb2 on January 22, 2010 at 19:52:29 from (99.240.236.11):
In Reply to: setting the timing on a 574 diesel d239 engine posted by johns48b on January 22, 2010 at 17:32:38:
Hi John, if you didn't turn the engine over or moved the timing gears or loosened the cap screws on the injection pump drive gear then the injection pump is installed 1 rev out of time.
Remove the injection pump again and rotate the drive shaft in the direction of normal travel 1 revolution and re-install. Then set the timing via the lines in the injection pump. I have the I&T Shop manual for D-239 in 684. It will be same as 574.
Post again if you can't get it timed.
Good luck
JimB
