Question about engine sleeves
Posted by FarmallHFFA on January 23, 2010 at 17:18:18 from (75.167.239.71):
Everyone,
The boys started with engine overhaul. This tractor ran great, tons of power, but burned oils. So, we pulled the head thinking it would be values or rings. Opened it up and it has a IH Power CRater kit in it, rear two cylinders were very clean, Fron one had oil sitting on the piston, and second one looks like it has had oil being burnt. Anyway, I the sleeves, seem lose in the block, as we turned the engine over without head on the sleeves in 3 of the 4 cylinders pushed right out. The #1 cylinder seemed to have a ton of oil in between the sleeve and the cylinder block. Could it be possible to have oil being pushed up into the combustion chamber in between the block and sleeve? What should we do if the sleeves are not tight?
We have worked on H"s Before and never had sleeves just come out unless the engine was locked up and then sometimes the sleeves would come out with the pistons. I have never had dry sleeves come out just by pulling on them wiht my hands.
So, Should we have the blocked bored and put in over sized (OD) Sleeves? or just try to put new sleeves & Pistons in and hope it fits properly, or last option, hone the block and slid in old sleeve, rering the pistons and try it? Sleeves and pistion look great, just come out easy.
Let us know, and thank you for the help
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
