Re: 1948 Farmall M tricycle front
Posted by jbradley on January 23, 2010 at 18:01:10 from (64.198.67.66):
In Reply to: 1948 Farmall M tricycle front posted by Ronnie Knox on January 23, 2010 at 09:36:05:
Just had this happen on my Super M. Thought I had bearing problems and found that the inside race was turning in the hub. I welded the outside of the race and then ground it down to a tight drive fitnessinto the hub. Seems to have worked. The actual noise was that the bolts were slightly loose that holds the rim to the hub and it had a knocking sound. It really travels when you are on the tractor. Thought I had transmission bearing noise. Has anyone else solved the problem as I have decribed?
