Re: farmall 504 #1 cylinder compression found broke push rod
Posted by 504-1 on January 23, 2010 at 21:08:47 from (216.145.144.254):
In Reply to: Re: farmall 504 #1 cylinder compression found broke push rod posted by Toro in Texas on January 23, 2010 at 15:44:42:
Anybody that sells IH parts will have one either new or used will be cheap. The valve stuck open and then the position closed it. Oil the valve and with a block of wood and a hammer tap the valve to loosen it and work the oil into it. The valve will Snap shut after you hit it down, and if it doesn t Snap it is still hanging up. This would be a good place for Marvel Mystery Oil. Just be sure not to hit the washer like retainers on the valves just the stems(you can hit the valve stem and the retainer but not just the retainer) if you hit the retainers only they can come off and the valve will fall into the cyl and then the head has to come off. Any ? just shoot an Email.Kevin
