Re: Super A Thermosyphon - Is it working?
Posted by rustred on January 24, 2010 at 11:53:53 from (74.198.148.46):
In Reply to: Super A Thermosyphon - Is it working? posted by Jimps on January 24, 2010 at 11:29:27:
the thermosyphon is a slow gradual process , and you cant really see the water circ.its not like a water pump that you can see the fluid moving.if your burping bubbles you may have compression in the cooling system.if its not running hot thats a good thing.they usually run hotter than a water pump equiped unit.the lower rad should be cooler than the top of rad.
