Re: 1 wire alternator
Posted by tackhammertime on January 24, 2010 at 16:28:28 from (65.1.234.192):
In Reply to: 1 wire alternator posted by brian 1855 on January 24, 2010 at 15:43:11:
No the mount is all the ground you need. Amp meter to the stud will show charge so will your guage. On my H you have to get to around 1/4 throttle but right after startup it don"t take long for the guage to drop back to center. On my A shows charge at less throttle. Turn on the lights and watch your guage it should not discharge if it is working. Also if you don"t run the tractor much put a disconect on your battery.
