Re: 1 wire alternator
Posted by Rick Deere on January 24, 2010 at 16:28:34 from (216.163.8.100):
In Reply to: 1 wire alternator posted by brian 1855 on January 24, 2010 at 15:43:11:
Run it up full throdle for a second, the gauge should show charging, should charge normal after that,if it dosent, see if it will hold a screw driver on the back of the alternator, should act like a magnet. if not its not working.
