Re: 1 wire alternator
Posted by nail pounder on January 24, 2010 at 16:52:01 from (207.255.123.66):
In Reply to: 1 wire alternator posted by brian 1855 on January 24, 2010 at 15:43:11:
mounting the alternator is all it needs to be grounded.if there is no amp meter on the tractor,check the battery voltage before and after startup.it should increase to around 14 depending on load.most of time the motor needs to be reved to get it charging if only one wire is used and should charge at idle.if b blade terminial is wired to the battery it will start to charge at motor start up but is not nessacary.alternator is most likely neg ground and so the battery needs to be also.coil wires may need to switched too. starter does not matter
