If you used sand paper you goofed big time. Sand paper leaves sand behind and that is turn makes the points dirty. Take some clean card board like what the points came in and pull that through the points a few times then try to open and close them. If you still do not have spark pull the wire off the distributor side of the coil and with the ignition on put it on and off and see if you have spark there. be sure to have the points sitting open when you do that. If you have spark then you have a short. If you have no spark then close the points and try again. If you still have no spark then the points have a problem and are still dirty. Oh there is only 2 things you should use to clean points and that is the card board trick or a TRUE points file which costs all of a buck and most parts stores have them
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
