sounds like you have a ground problem,you said you have power to the points if i understand you correctly, if this is correct take a test light connect it to the the stud bolt that the dist. wire and condensor attach to on the points,with the points open ign. on, touch engine, if it lights wiring is ok,if not check to see that condensor wire or points spring didn't get turned against the dist. when tighting, next touch lower half of points,if it lights contacts are the problem, if it doesn't, touch dist. plate that points are mounted to, if it still doesn't light you have a bad ground connection between plate to dist, or dist to engine.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
