Re: 1 wire alternator
Posted by Jon Hagen on January 24, 2010 at 22:26:48 from (69.26.23.125):
In Reply to: Re: 1 wire alternator posted by Loren in MN on January 24, 2010 at 21:26:35:
Pretty easy deal loren. Several of the aftermarket company's will sell you a complete 6V or 12V pos ground Delco 1 wire alternator.(even JC Whitney).
If you want to rebuild a used neg ground 12V Delco alternator into a 1 wire pos or neg ground 6V or 12V alternator, all the parts come in a kit. The 6V or pos ground alternators or kits are very little more $$ than your standard rebuilt Delco 3 wire 12V neg ground alternator.
Get on a search engine like Google, and type in the search box "1 wire 6V alternator", or "1 wire pos ground alternator."
Quite a few parts suppliers have them.
