Re: Seat pivot support rod and bushings
Posted by eastsider on January 25, 2010 at 06:10:43 from (24.111.107.170):
In Reply to: Re: Seat pivot support rod and bushings posted by BruceS. on January 24, 2010 at 12:06:46:
You put the "support rod" in first, then you put a flat washer over it on each side inside the outer tube...the bushing sits against the washer on the inside...the washer also helps center the rod in the housing.
