Re: 1 wire alternator
Posted by SDE on January 25, 2010 at 06:23:21 from (174.124.13.81):
In Reply to: 1 wire alternator posted by brian 1855 on January 24, 2010 at 15:43:11:
I have one on my "C". To excite it I would have to pull the throttle rod to get some extra RPM out of the engine. I changed the size of the pulley and life has been great since then. The battery is always fullly charged, even when I let it sit all winter. I think my 400 is a one wire also.
SDE
